7 members (NJC, baldeagle, Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna), 77 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#931407 03/29/2013 11:05 AM
My wiper switch has been jacked up for quite a while. It works, sometimes by itself, sometimes it won’t shut off, just generally jacked.
My dilemma has been that I don’t want anything but the original style washer nut and original knob showing and I have yet to find a good used original.
Anyway, I found a new “replacement” at American Classics that had the right threads for the washer nut. That was a plus. However, the [censored] knob that came with it had about ½ the diameter of the original. I didn’t have pipe to use as a spacer, duct tape was to squishy, you know, all the normal bubba stuff wasn’t working.
So I went super bubba.
I put the old switch in a vise and drilled it out to a tight fit over the new switch shaft. It left the old shaft thin, but substantial enough to hold up well. I recommend drilling and fitting it before cutting the old one off.
http://img.photobucket.com/albums/v...ecuttingoff_zps031303a2.jpg?t=1364511067
Once it was drilled out, I sliced it off the old switch shaft and mounted it onto the new one.
http://img.photobucket.com/albums/v...enewspacer_zps4bc84f89.jpg?t=1364510917b
The sumbitch fit like a glove.
http://img.photobucket.com/albums/v...inalmatchup_zps525cf3f8.jpg?t=1364510904
This is the final mock up. Now I just have to wire it and button everything up.
http://img.photobucket.com/albums/v...finalmockup_zpsd3f479b0.jpg?t=1364510864
Once it’s installed, you can’t tell it from factory. Bubba or not, it worked well.
Avette4me #931421 03/29/2013 12:54 PM
sweet
This should be a Tech Article...good job!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike!
Moderated by  ndkid275, Phak1
