2 members (baldeagle, elhippie64), 57 guests, and 10 robots.
Topics128,020
Posts1,055,345
Members48,420
#9325 04/04/2003 7:37 PM
What is the best way to rerout, or replace the fuel lines to prevent vapor lock on a 235?
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#9326 04/04/2003 7:49 PM
You might try the old flathead **** trick of putting wooden clothespins on the fuel line between the fuel pump and carby to act as heat sinks.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#9327 04/04/2003 7:57 PM
Don't forget the aluminum foil and yes it does work. used it when I dragged race 30 yrs. ago and the boys stock car. popcorn
The Truth is Out There (It's in the Smoke!)
#9328 04/04/2003 8:03 PM
Thats what a friend of mine said, but I thought that would look Ugly!!!
And remember no matter what they say, looks matter
Brian
#9329 04/04/2003 8:51 PM
BrianK: All kidding aside if you want purty go with the covered hose that your local auto stores sale, the biggest reason for vapor lock is heat, that braided line looks nice and it helps insulate. popcorn The Truth is Out There (about $17.00 have it on my 350)
#9330 04/04/2003 9:11 PM
Carburetion specialist
A way to minimize (I'm too old to say completely eliminate!) vapor lock is to insert a three line filter at the carburetor, and run a return line from the "vapor" port of the filter back to dump into the fuel tank.
Am not aware of anyone who has experienced vapor lock after making this modification.
Jon.
The Carburetor Shop
