| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I've removed 4 (broken) leaf springs on the front of my 52' 1/2 ton on each side dropping the front about 2" and I plan on lowering the rear about 3" with a block kit. I want to get all new shocks and was wondering if I will need lowered/shorter shocks or can I use the factory length? The truck is all stock. Thanks | | | | | Joined: Jan 2013 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 89 | Lowering shocks will most likely perform better. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It really depends on how much stroke your suspension/shocks have left at the lowered ride height. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Didn't know there was such a thing as lowered shocks. Where do you get them? Would my FLAPS have them?
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | |
