5 members (Otto Skorzeny, 2-Ton, TexasJim50, MickeyP, MRMEROTH11), 117 guests, and 3 robots.
Topics128,132
Posts1,056,383
Members48,441
Apprentice
Apprentice
I am changing out the original gauges on my 61 Chevy C10, I am installing Dolphin gauges.
Anyone with tips on how to do this correctly?
None of the gauges are working right now, I believe this is due to the original motor being swapped out to a 350 and wiring being changed.
Maybe I am wrong, but hope not.
JS
Riding in the Passing Lane
You must use the sending units that come with the gauges. The engine size would not matter as long as the senders are installed in it. The wire from the sender goes to the correct terminal on the gauge & the wire that comes on with the ignition switch goes to the pos. side of the gauge. On the voltmeter the hot wire from the switdh goes to the pos. & the neg. is grounded.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Thanks Wrenchbender, I was hoping it was as clear as just putting the right wire on the right terminal.
What about the gas tank sender? anything I should look for or watch out for on it?
JS
Again you have to use the sender that comes with the kit. You may need an adapter for it to fit. On the temp sender it usually goes in the outlet between #1&3 spark plugs. A reducer should come with the kit or is available at a hardware or parts store.
