Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, carbking, tclederman), 152 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
Page 2 of 2 1 2
Cletis,
This is ancient history, but relevant to some recent alternator posts. Your schematic does show the idiot light and you can see how it works in the circuit. The filament in the "gen" light, the resistance wire in this line, or the ever present diode all serve the same purpose, which is to limit current to the alternator after start up, and to limit the amount of voltage that is allowed to flow back to the ignition switch when the engine is shut down.
I guess the conclusion would be, if you don't have a dash light, you use a diode. If you WANT a dash light, you can rig one up INSTEAD of a diode. I don't know what value the lamp would be, but it would be small as not to pass much current through its filament.
So much for old posts...I was stoked because I opened the wiring diagram in the link you provided, and after MUCH searching, traced the alternator #1 through the little light and into the ignition switch. Nuff said! smile
Stuart
Hi Alan,
What is the function of the #2 terminal block?
52Ted
illegitimi non carborundum
Hey, 52Ted
It's just to allow for more connections. Simple as that.
Those terminals supply a full 14 volts to whatever I hook up to them -- and that includes my fuse box which originally had a smaller and much longer wire bringing power to it, which meant less voltage.
If you make that modification to your truck, you will see and feel a difference.
I'll tell you what also made a real noticible difference, too, was using a fusible link on my electric fan instead of a circuit breaker! All the info is at my site.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Page 2 of 2 1 2
