| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | 55 Gmc series 2. I've been having problems with the brake lights not working, found it was the wires that connect to the brake light switch. I've tried everything to secure them better to no avail. Anyone have any recommendations on this or know if there are specific fasteners to use? Here is the switch: http://www.classicindustries.com/images/productimg/t/t70850.jpg
1955 GMC 100 Series 2
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the connectors on the harness wires are old and worn out, find proper size female bullet connectors to replace them, but make sure the problem isn't that the wires are too short or improperly routed and getting knocked off by the pedal arm when you use the brakes - should be a wire clip nearby to hold them Bill | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks Bill. Good point on having some extra slack. Are all female bullet connectors the same size or are there difference sizes?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wire size differences, if ones fitting the wire properly are too big or small they can be opened up or crimped down to fit tightly
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are also different sizes on the business end. | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | I used the female bullet connectors, that I got from advance auto, for 48 gmc, works great. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used those connectors too and they work perfectly. Anytime you have need to connect a smaller wire into a larger crimp just bare twice the length and fold it over before inserting. | | |
