0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 11 New Guy | | New Guy Joined: Jul 2010 Posts: 11 | Hello everyone I've got a 54 3600 with the original 235 and want to give the engine some hotrod mods like higher compression maybe a cam and/or bigger valves.
I am wondering if anyone has done this instead of going for the crate engine.
Thanks Randy | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Randy,
Welcome to Stovebolt.com.
By "crate engine", you are most likely referring to a GM 350 engine?
Hundreds, if not thousands, of Stovebolters have "enhanced" their 216/235/261 engines.
Try searching on some key words and you will get thousands of "hits"
Here are some upgrades to your generation of 235. Some require significant engine work and others are bolt-ons.
1. Dual exhaust (search on the word Fenton or on dual exhaust)
2. Improved cam - the simplest/cheapest is most likely a cam for a 261 (you should get new lifter with a new cam). Many people go for more modified-lift cams - they are readily available from several vendors.
3. Increased carburetion to match your "new" engine. A larger single carb is easier, but people who like bling go for 2,3,5 carbs (and often do not match those carbs to what the engine can use).
4. Change your head to the common "848" head (1956-1963 casting code 3836848). This is a higher compression head compared to one on the 54 (maybe an increase from 7.5 to 8.25, if you use the right valves/springs/rotators).
Other people will post other ideas.
| | | | | Joined: Nov 2012 Posts: 20 New Guy | | New Guy Joined: Nov 2012 Posts: 20 | Gettin ready to pull mine for a rebuild soon. Gonna bore it .40 over, shave and port the head, and maybe shave the block. Also doing an RV cam. Got a dual carb Fenton intake and header for it as well.
1950 3100 all original for now
| | | | | Joined: Jan 2010 Posts: 12 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 12 | I have a '54 block bored .60 over, milled the head and did a port and polish, have a dual carb set-up but will be changing it over to a corvette intake tripple side draft (with harley davidson carbs) fenton headers, a mild 3/4 race cam from patrick's and a dual point ditributer.
Thomas | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Porting the siamese head to improve flow is easier said than done which a flowbench will verify. I'm slowly getting around to uploading pictures that vanished with the demise of Webshots and now have section views of the head showing wall thicknesses here.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | I have a 55.1 235 bored .60. Replaced original head with "848" head off a 56 235. Offy dual intake with water heat and Carter Weber carbs purchsed from Tom Langdon (Stovebolt Engine Company). Fenton cast iron headers. HEI distributor also purchased from Tom Langdon. I purchased a mild cam upgrade and lifters from Patricks. I couldn't be happier with the way it runs. Very responsive. It is everything I had hoped for.
Grant | | | | | Joined: Jul 2010 Posts: 11 New Guy | | New Guy Joined: Jul 2010 Posts: 11 | Anyone familiar with the 235 2nd edition 1954 Corvette cam. From what I read it picked up almost 15 horse. Was wondering if that would be an easier swap then some of the other cam shafts yall have talked about. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If I'm not mistaken, the Corvette camshaft is the same as what you would find in a 261. The Corvette also had a split exhaust and tri-carb. | | | | | Joined: Mar 2013 Posts: 217 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 217 | themmer, have you done the 3 carb set up I was thinking the same thing. I'm putting a 270 gmc in a 31 chevy pickup and thought the 3 side drafts would be cool. I've been shopping for Harley cv carbs but can't seem to find any good buys on them. Jay D | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Will side-draft carburetors interfere with you 31 pickup's steering column. I assume the 31 truck has a transmission with a floor shifter? Here's a discussion (with pics) of 3xCV carbs on a 235. | | | | | Joined: Mar 2013 Posts: 217 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 217 | tclederman, thanks for the discussion thread. the steering column is ok, but the jimmy is a couple inches longer so the rear carb is going to be close to the fire wall. I have to build my manifold so I may need to dog leg the end carbs in to the center a little. | | | | | Joined: Jan 2010 Posts: 12 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 12 | I'm still working on the tripple setup. I have the carb mounting figured out and need to get some throttle shafts made as I want to run soild linkage instead of using cables. I will try and get some new pictures taken with the carb mounted on the intake.
Thomas | | |
