3 members (60steve, TexasA&M48Truck, Wayne67vert), 78 guests, and 2 robots.
Topics128,212
Posts1,057,463
Members48,471
I am trying to experiment with rebuilding clam shell upper lift gate hinges and to see if the later style (1951-55) will fit in a (1948-50) with minimal work. I want to document the work. Does anyone know where I can get a couple of the older style hinges for parts so I can continue the modification. I placed an ad in the swap meet with no response, maybe I can talk to a couple of guys that have replaced or modified their hinges and maybe find a source for my parts. shoot me a PM or email me with pictures of what you have done to deal with broken or badly worn hinges. Thanks.........g
"G" my hinges are warn out as well. What can I do to help us?
Scott
Chevytruckdaddy
send me some pictures of what problems you are having with the hinges and we can come up with a repair plan. I think it was Patrick that repaired his worn hinges by welding and grinding.
What year is you suburban? I am looking into adapting the newer style into the 1947/50, I think it is possible, but I have to do some more research.
I think I have a pair of both years... Those from my 49' and the later ones. I can try and get pics later after I dig them out.
Did you need specific pics?
Eddie, I have pictures of both sets, in fact I now have both sets. What would help me is pictures of the mount opening on the header with dimensions of the opening. I did a quick check this morning before I left the shop and I think that I can make either styles work. I believe the opening might differ, I only had a 1951 header to work with and the 48 still has the hinges installed. Unfortunately they were welded in and I could not see the actual opening.
Yup - It was me. I also still have a NOS 49 hinge as well. I may still have photos George. [email protected] I did the repair myself, but I suggest that if you're not an advanced welder, have somebody else do it.
I took the NOS hinge, measured it out and tig welded up the channel and measured it out and filled it and ground it out
