3 members (Uncles51, Woodcmiami, Mitch4445), 53 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#93146 10/15/2005 3:52 AM
Apprentice
Apprentice
Just converted my 54 to 12 volt. Took 6 volt to 12 volt out of radio power. Wired 12 volt radio to 12 volt supply. Lot of engine static now. What would be a good suppresser? Has new composite plug wires and worked fine before.
#93148 10/15/2005 6:36 AM
Since you probably changed the generator and regulator I'd check those first. The condensors should all be checked or installed if none are in place now.
