| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | what was the stock rim size that came on a 1950 3100 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "stock" varies with GVW, consult your shop manual load chart, or resto pak - they're available onlineBill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 48-51 shop manual load chart [for '50] indicates either 15 or 16" would be "stock" Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim, the last link I gave shows the load chart for 1950, and as I said, it shows both 15 and 16" for the 3100 at 4200#GVW - obviously either 15 or 16" would be available "stock", ie: from the factory when they attached the GVW tag, not 'special order' or aftermarket, what was "standard" is speculative and would no doubt depend on the particular plant/dealer/area .... asking "what was the configuration of a year" can not be answered other than by reference to the manuals and evidence on the specific truck asked about, such as the GVW tag - or by the original purchaser
Bill | | |
