8 members (Hotrod Lincoln, 2-Ton, DadsFirstPickup, Otto Skorzeny, HandyAndy, Peggy M, DES57, Jman),
124
Mod | | | Forums66 Topics128,102 Posts1,056,532 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | Hi everyone,
Truck is a 1951 3100. I want to do a little work on the floor boards (if it ever warms up enough) and want to put in new floor seals around the brake, clutch and accelerator. I was looking closely tonight and I can see the metal retainer that they look like they would slide into. My question is do I have to disconnect the linkage to slide the felts over the rods and into the retainers? Other tricks or suggestions.
Thanks in advance for the help.
Chris | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You could split them but they are meant to have the pedals and rod go through them. They make for a much quieter ride when installed correctly. | | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | You should take the pedals off to replace those felt seals. Not just because that is the correct way to do it, but also so you will have the experience and satisfaction of knowing how to reinstall and align these parts correctly. I'm talking about braggin rights, impressing your friends.
