1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have a 235 that is going into a truck that originally had a 216, so the manuals are not of much help, as it lists the parts for the 216.
So, what is the best way to get a compatible vehicle type for when the parts guy/gal says 'for what vehicle'?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | whatever year the engine is, and car or truck
Bill | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | So if I say 55 GM truck I am going to get the right parts? I'm looking at doing a tune up and needed points/plugs rotor... but even I thought how do I know what to get?
So will any 1955 GM 235 truck part work? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | So if I say 55 GM truck I am going to get the right parts? I'm looking at doing a tune up and needed points/plugs rotor... but even I thought how do I know what to get?
So will any 1955 GM 235 truck part work? No. Casting #s find yours and go from there...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some more major parts may differ, but electrical tune up bits will be the same for any 55 235, as well as gaskets .... but call it a "55 Chevy truck", not a "GM" or you'll have'em tellin you GMC didn't have a 235  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "So will any 1955 GM truck part work?
. . . some more major parts may differ, but electrical tune up bits will be the same for any 55 235, as well as gaskets .... but call it a "55 Chevy truck", not a "GM" or you'll have'em tellin you GMC didn't have a 235"
There are differences between early USA 1955 235 engines and later USA 1955 235 engines (identified by a "55" or a "255" in the engine serial number). The 6v/12v difference most likely won't affect the "tune up bits", but some of the gaskets will be different.
And, Bill's comment about "GM 235" and GMC not having a 235 is for us Americans. As Bill would know (but, I am only assuming), a 235 engine might have been used in a 1955 Canadian GMC small trucks (a 235 was used in 1954 GMC small trucks).
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have the casting number web pages bookmarked, so I will take that info with me.
Would it get me 'closer' to the right parts if I used the SN on stamped after the distributor?
Is one more accurate than the other? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, "the SN on stamped after the distributor" is the Engine Serial Number I referred-to in the post above.
What is that serial number?
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I THINK my motor is out of an 1958-9 3700 truck
The engine SN is FIII9K - Flint, MI Nov. 19 34-35-3700 truck
Head - 3836848 Block - 3764476 58-62 235
K 18 8 December 18th, 1958
Is this correct? Other than the motor mounts being on the side, and not under the crank pulley is that the only real major difference compared to a mid 50's 235?
My truck has the motor mounts for under the crank pulley. It looks like I can just drill the flange on the front cover and use that with a rubber mount.
Or will that not work either??
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good job on the decoding.
The location of the water pump and fan is different. And, the 1958 fan will be too close to the radiator.
Pre '68 Dave makes a relocation plate. You use the original style water pump; and, the plate places the old style pump in the correct location on the new style block.
This provides better cooling and you do not have to fool around with getting a short shaft water pump (or shortening the shaft on the water pump),
Your solution to the front mount is correct.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Thanks for the verification. I have a lathe and mill so I just may fiddle with shortening the pump shaft a few inches. I have a 52 235 with the water pump to take measurements.
If I get fed up I'll look for this adapter plate.
Thanks to all that helped! | | |
