2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#930948 03/27/2013 2:12 PM
i was wondering if there is some kind of adjustment for my clutch on my 49 3800. It drives in first and second, and also reverse, but its slipping when u put it in third and forth like its not engauging all the way. Or is the clutch just plain wore out?
It has been my experience that clutch slipping problems show up first in the higher gears. Do you have free play in the pedal?
1951 1 Ton Completed
The clutch pedal is tight so i will try to adjust it for free play thanks for the tips i wasent aware there was online manuals like that thanks for the link
b10 Offline
clutch retracting springs ? can you get them or just a whole clutch unit ?
Moderated by  Dusty53
