| | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | In a 2011 Summer Eastwood catalog they have a compressed air paint sprayer, its like a spray can that you pump up to use. It does not use a cartridge for pressure it has a tire type valve, you fill it with paint and pressurize it with air and go for it. Its on Page 66 and number 11181, its called "Eastwood Rechargeable Aerosol" It is discontinued. I've seen others that you have to keep buying propellant for I personally don't want to have to keep buying or trying to hunt down discontinued propellant cartridges. So I'm looking for something like this sprayer.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2010 Posts: 1,723 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,723 | In a 2011 Summer Eastwood catalog they have a compressed air paint sprayer, its like a spray can that you pump up to use. It does not use a cartridge for pressure it has a tire type valve, you fill it with paint and pressurize it with air and go for it. Its on Page 66 and number 11181, its called "Eastwood Rechargeable Aerosol"
It is discontinued. I've seen others that you have to keep buying propellant for I personally don't want to have to keep buying or trying to hunt down discontinued propellant cartridges. So I'm looking for something like this sprayer. You might try this: http://www.bedbathandbeyond.com/product.asp?SKU=11318517Watch the demo. Olive oil is thick so it probably would spray paint. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you don't want to get a compressor to use a 'real' spray setup, look into an airless sprayerBill | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | if you don't want to get a compressor to use a 'real' spray setup, look into an airless sprayerBill I have the comp etc.
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | I just noticed the Northern version says "Not for paint" | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Wayne67vert: That thing from BB&B is amazing, might just work for small spot work. Wonder if you can clean the paint out with laquer thinner? Might just melt all the innards??
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Sep 2010 Posts: 1,723 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,723 | Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | What's wrong with a small cheap air brush? HF sells one for about the price of that BBB thing and it won't melt when you put reducer it it to clean...
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Love that Romainion paint version. Bet that will make you stop smoking!
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | any GOOD paint supplier will mix/match any color and put it in an aerosol can for you. If you have a hard time finding a place call Automotive Color and Supply in Indianapolis - 4415 Saguaro Trail, Indianapolis, (317) 290-8690
....David
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I bought one of those rechargeable spray cans from J.C. Whitney years ago. You put the mixed paint in it and charged it with an air compressor. Wasn't worth a dime for painting, it doesn't lay down a very smooth paint job, has spits and splats as you go. The only plus I got from it was it came with an 18" long accessory tube and 4 way spray head that I would attach to regular spray can rust preventive primer and spray inside panels with it..... save your money. Best thing I've found for painting small items and trimming is a small spray trim gun. You can buy one at HF for about 20 bucks or so.... John | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | if you don't want to get a compressor to use a 'real' spray setup, look into an airless sprayerBill I have a compressor, but I also have an 'unreal' HVLP airless (turbine) sprayer that is superior in all regards to a compressor sprayer. Takes up almost no space and cost much less than a good compressor (which I also bought later to power a blast cabinet). | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Tim, the BS does go on  Bill | | |
