| | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Looks like I'm playing catch-up today for posts...
Anyway, while I was driving my '57 3100, the heater core let go...steam came out the defroster vents, coolant pouring out of the heater box.
I searched the shop manual online, but couldn't find anything on removing the heater core...
So how do you do it?
Thanks...
Chris | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | heaters are in the 57 accessories installation manual, but there's no place that shows construction/repairs .... specifics depend on which heater you have, but you need to remove the heater from the truck and disassemble the case, all of which should be pretty obvious after consulting that manual .... maybe some help on the deluxe version in the heaters album linked below Bill | | | | | Joined: Feb 2013 Posts: 5 New Guy | | New Guy Joined: Feb 2013 Posts: 5 | I'll pop the hood on my '57 to take a look, but as I recall, there were just studs on the heater box, that went through the firewall. | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | M -
You are absolutely correct. After eyeballing it for 15 mins or so, I pulled out the battery, the firewall mounted battery box, undid all the studs and pulled out the heater core box.
Guess I lucked out on that one...
Chris | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Yeah and you can't do a heater that fast in a lexus.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
