| | | Forums66 Topics128,196 Posts1,057,387 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93057 10/03/2005 2:11 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | Can anyone tell me about installing some small speakers in the top front corners of the headliner. I have a '52 with a new CD player in the dash, and a DVC speaker mounted in the original speaker location on the dash. But I would like to add two small speakers in the headliner. If anyone has any pics of speakers they have put into the headliner I'd like to see it and hear how they mounted them, what size speaker you can get in there. Anything at all.
thanks, Crow | | |
#93058 10/04/2005 4:53 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | If you can find a pair of low profile speakers, they may fit; but I don't think you'll have enough clearance.
Then again, I'm not sure how much room there is between the headliner and the roof in a fifty-two. The best way is to pull the headliner and measure.
As for the mounting, I would mount them to the headliner, wire everything up, and then remount the headliner.
But that's just me. | | |
#93059 10/04/2005 11:49 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Go to a junk yard and find the small 1 1/2'' speakers these are mostly tweeter type speakers. Do it, and you'll love it. But you will now have a speaker close to your head. There is quite a bit of room up there for a small speaker and headliners kits are cheap.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#93060 10/05/2005 4:33 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got a 37 pick up. I mounted kick panel speakers in the headliner over my head. There was plently of depth and I did it with the headliner installed. Just cut a round hole the correct size and ran wire. Now I can hear my radio! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#93061 10/05/2005 7:26 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | Well I picked up some 3.5 inch speakers that will fit into the headliner area at each side. Onto ideas for subwoofers. | | |
#93062 10/18/2005 2:29 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | Just wanted to update y'all that I put in the 3.5 inch Infinity Reference speakers in the top front corners of the cab. The sound is great, its better than any factory system I have had in my cars. I'm thinking of changing the dual voice coil speaker in the original location on the dash to a second pair of 3.5 inch speakers. | | |
