0 members (),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | I currently have a 1954 3600 that is nearly up and driving. Now its pretty stock and i plan to keep it that way for the most part, at least for awhile.
Its been kicking around in my head for a year or so though of possibly converting it to a 4x4 set up in the future as i do a lot of work out in the woods and plan on using the truck for it. Now its my understanding that a Big Bolt, that is 1 1/2 ton and bigger have similar cabs but larger front end sheet metal - hood, fenders, etc. If I were to swap that on to my 3/4 ton the larger fenders would give me more clearance to run some bigger tires on the truck and generally give me more room. I just found for sale locally a 51 1/12 ton flatbed for $400. Sheet metal looks in decent condition, generally a nice looking old farm truck and a smoking deal.
Question then is, how difficult would this swap be? And would the difference in grilles, park lights etc between 51-54 cause me major grief trying to adapt? Id like to keep the 54 grille and overall look, but use the older big bolt fenders etc for improved clearence.
Maybe i should just find a big bolt 54...
Any advice is appreciated,
Chooglin | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | can't use just the fenders, the whole big bolt front is a package - I think you'd have to run some reaaaaly big tires to make it not look like a clown car, and I doubt using the light truck grill would work out .... drive what you have until you get the $400 truck converted to 4x  Bill | | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Thanks for the reply Red, thats kind of what i was thinking too. Little more hassle then worth. Probably just end up passing on the deal... dont have a really great place to put it unless its in pieces and ive got quite a bit invested in the 54 as is. Just came across it and it seemed like it might be what i was lookin for and a great deal ta boot. Still open to ideas but was kinda thinkin the different grille and park lights might bugger me.
The search is on for a big bolt '54 then i guess.
Chooglin | | |
