5 members (J Lucas, Gray_Ghost, msmall, 2 invisible), 93 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#930116 03/24/2013 2:08 PM
Howdy;
On my 4 speed SM420 (I believe), how does one go about removing the stick from the trans housing? I think I have to press down on the retaining ring, but does it turn clockwise or counter clockwise? And should I be in any particular gear? I can get it to push down, but having a heckuva time getting the thing to rotate.
Thx - Bruce
The locking collar turns counter clock wise, and the trans should be in neutral. That collar can be a bear to turn if it hasn't moved lately, I use a short piece of pipe with a rough end that fits on top to help turn it.
Leo Offline
Moderator
Moderator
Bruce, misrilou has it correct. Mine is doable by hand, but tough. It's like taking a tail light bulb out of a housing, only tougher.
I've used a large channel lock plier to help turn when I push it down.
That did the trick guys! I took a 12 inch piece of wood and drilled a 1.5 inch hole along one edge. Used that to press down on the retaining ring for about 15 minutes, it finally loosened up and came free.
Follow-up question: Are there any rubber or leather washers in between the retainer and cup? Or between the cup and spring?
Thx - Bruce
Nope, this is the whole shootin' match right here:
http://www.pbase.com/dennygraham/image/117851895
dg
Denny G
Sandwich, IL
