| | | Forums66 Topics128,051 Posts1,055,705 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Howdy; On my 4 speed SM420 (I believe), how does one go about removing the stick from the trans housing? I think I have to press down on the retaining ring, but does it turn clockwise or counter clockwise? And should I be in any particular gear? I can get it to push down, but having a heckuva time getting the thing to rotate.
Thx - Bruce | | | | | Joined: Nov 2012 Posts: 15 New Guy | | New Guy Joined: Nov 2012 Posts: 15 | The locking collar turns counter clock wise, and the trans should be in neutral. That collar can be a bear to turn if it hasn't moved lately, I use a short piece of pipe with a rough end that fits on top to help turn it. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Bruce, misrilou has it correct. Mine is doable by hand, but tough. It's like taking a tail light bulb out of a housing, only tougher. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've used a large channel lock plier to help turn when I push it down. | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | That did the trick guys! I took a 12 inch piece of wood and drilled a 1.5 inch hole along one edge. Used that to press down on the retaining ring for about 15 minutes, it finally loosened up and came free.
Follow-up question: Are there any rubber or leather washers in between the retainer and cup? Or between the cup and spring?
Thx - Bruce | | |
