1 members (Shade Baby),
71
Mod | | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | First off I am not an engine guy so bare with me. 1977 Chevy c 10 with 1978 corvette 350. I had the engine rebuilt. I had edelbrock proformer intake and a Holley 800 plus 4 bbl. every time I turned off the engine and pulled in my garage all I smelled was gas. I talked with Summit Racing and they said I had way to much carb for a 350. I bought a 650 edelbrock and performance is way up and Idle is much better but gas smell is still there. I am thinking The intake has issues?? please offer any advice. Paul | | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | | | | | | Joined: Sep 2010 Posts: 1,715 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,715 | Are you using ethanol gas?
I had leaks with my Mustang causing rubber hoses and gaskets in the carb to deteriorate. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | x3, look carefully everywhere for small leaks, and check the exhaust for evidence of still running rich
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to run a vent hose from the carb bowl to a charcoal cannister. Then run a hose from the cannister to ported vacuum on the carb. I have had this problem on all my old trucks when I bring one home. After it cools down its OK. You can throw a damp towel over the air cleaner. You can leave it outside till it cools off & then put it in.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Please state if you have found any leaks??? If you are running a mechanical or electric fuel pump that delivers more than 6 PSI, that very well could be your problem.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | On the 73-87 trucks there is a vapor line that runs from the fuel tank out to the radiator support which connects to the vapor canister, make sure that is connected. Gas fumes will com out of that line if it is open. Also Check the float level on your carb. Holly's arent always ajusted out of the box. Some times the float level on the secondarys are a little too high, while at an idle gas will drip into the secondarys & you will get a gas smell from that.
Pull the sight plugs out each float bowl & check the fuel level. If gas pours out of the hole, then the fuel level is too high. The fuel level should be level with the bottom of the hole.
If you do need to adjust them, there is a 5/8 lock nut with a screw in the middle on the top of each float bowl. Undo the screw & turn the nut to raise or lower the fuel level. But like everyone else says first check for leaks. Also check any rubber fuel lines. Ethanol raises hell with the older rubber fuel line material. Any new rubber fuel line that is sold today, supposedly is compatible with Ethanol. Good luck, let us know what you find.
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I misread your post, I just realized the you now have an Edelbrock carb. Im not sure about the floats on those carbs, but it is possible that may be your problem. With the engine running, look inside the secondarys & see if any gas is dripping in there. There should be no gas in there at all, until you stomp on it.
How stock is your engine? The 650 carb may be a tad too much. I was always told to go with a 600 on a stock 350, even with a little bit of cam. But it all depends on what you have. Just a thought.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The size of the carb has nothing to do with it. You will first have to determine if anything is leaking, Fuel lines, fuel pump, carb, fittings, hoses, filter, manifold, gas tank, wrong gas cap, vapor lines or internal dripping, as mentioned... need to find out where the "smell" is coming from, may not be carb. 800 smelled, 650 smelled. Be sure that there is no more than 6PSI pressure, as I said. Too big of a carb does not cause leaks (if there is a leak), just bad gas mileage and performance.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | May not be carb, may not be leak, but "all" of the above should be taken into consideration. Start with the leaks first, then go from there. | | |
