| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I have 1951 Chevy 3100 it has a mustang II front end, the spindles are ford with the 5 on 4.5 bolt pattern. My question is Are all or most spindles universal? I ask because I want to change the hub. I want to keep the 5 on 4.5 bolt pattern. So can i like change to a chevy or any other hub and keep the same spindle ? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Project_area_51, the bolt pattern on a Chevy hub is not the same as a F@#d hub, so first you'll have to decide which bolt pattern you want. Then if you spent some time with a good partsman looking at inner and outer bearing numbers, and front hub seal numbers you'd know if the two hubs in question have at least interchangeable parts. Then there is the bearing spacing/hub width issue to deal with. If you knew for sure what year parts you were trying to interchange, you could call a wrecking yard and ask them to look the parts up in their Hollander interchange to see if the parts are interchangeable, hope that helps. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I believe some of the manufacturers that offer MII front ends also sell rotors / hubs with the Chevy 5 on 4.75 pattern. | | |
