| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92981 09/20/2005 4:49 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | When I purchased my '46 GMC 2 ton (mapleleaf), it had no distributor cap and wires; but it did have the disributor in it. I cleaned everything up picked up a new set of points, condenser cap and wires. everything is good except for knowing where to put the wires on the cap, I know the firing order but where do I start? Help would really be appreciated... Thanks | | |
#92982 09/20/2005 2:47 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Canuck, Here is my version. I like to pull all the plugs first. Use a remote starter switch or roll it with the fan. With your finger over the front spark plug hole (#1) roll it over until you feel air rush out. Stop and pull it to top dead center by watching the timing ball on the flywheel through the bellhousing. This is TDC for #1 cylinder. The rotor now points to the area where the wire would go when the cap is installed. Make sure that the distributor adjustment is such that you can move it BOTH ways if needed. As long as #1 is at TDC, the distributor can be moved anywhere as long as 1# plug wire is over the rotor. If you want the distributor wire in a different position, feel free to move the distributor. You must make sure it seats in the oil pump if you do take it out. It won't seat on the block if it isn't in the pump so this should be obvious. I am assuming that GMC's have the bellhousing peep hole for the timing mark.
Stuart. | | |
#92983 09/21/2005 2:28 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | Thanks stuart I'll give it all a go..
Scott | | |
