4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#929477 03/21/2013 8:53 PM
Torque tube 1948 half ton.
Looking to replace three speed with a four speed. From a 1949 half ton is that going to be an easy fit without any adjustments?
oldchevyguy #929487 03/21/2013 10:10 PM
You'll need a 1/2 ton 4-speed u-joint assembly. A 4-speed yoke on the transmission side and a 1/2 ton 3-speed yoke on the drive-shaft side.
The 4-speed transmission will need to have the enclosed drive-shaft rear cover/housing.
Do you have the transmission rear-support/mount and the frame cross member (it was sometimes removed, but should be used with a 4-speed).
oldchevyguy #929502 03/22/2013 3:36 AM
If you are talking about an SM420 4speed you gain nothing by
replacing the 3speed with it. The 1st. gear is almost unsuable
it's so low, which means you'll be driving it in 2nd, 3rd and
4th all the time. I'm sure you are aware that high gear in both
is 1:1.
The four speed will add 70 pounds to the truck and the stick
will be in the crotch of anyone sitting in the middle.
If your 3speed is broke, they're a simple transmision to repair
and with a little searching 'round parts are fairly easy to find.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
oldchevyguy #929715 03/22/2013 9:51 PM
I did the switch. Simply to get a floor shift. That is all you get. And a granny gear to walk up walls.
I am happy. I have a floor shift
Dennis
oldchevyguy #929758 03/23/2013 7:33 AM
I have the U joints the yoke and the cross over member.Will 3 speed ball collar housing work.I just put 3.55 ring and pinion in .I do not carry any wight but I do not want to slip the clutch.From a dead stop, climbing a grade or pulling in to a tight space will the 4speed lower gears help?I must check and see what trans it is,SM420 Burge and Wearner.
oldchevyguy #929761 03/23/2013 7:45 AM
The 3-speed ball collar will work.
The 1st gear has been useful for me when I have 8 people in my 3.55 rear-end Suburban.
Also, the first gear is quite useful when you are in a parade, and for when you are competing in a slowest-truck race (be sure to decrease the idle speed, before entering such a race).
