| | | Forums66 Topics128,214 Posts1,057,484 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | | | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | I need master cylinder, all wheel cylinders, all brake shoes, hardware kit.
All that's on the truck are the drums. All other brake parts are gone.
Any recommendations to buy a total brake kit. I'm staying with drums all around. Possibly upgrade master cylinder.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check your nearest NAPA, should all be listed, but you won't find a "kit" for complete stock brakes, the items come individually or sets per wheel or front/back - some of the e-brake pieces might be hard to find if that's all missing .... also an 'upgraded' MC will be another individual item that will require it's own bits to adapt to the truck
Bill | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Find a late 70's early 80's Camaro/Trans Am rear (they are the right width) with a good ratio. Put a disc brake kit on the front with a new dual pot MC under the floor and save the trouble of finding used parts. Going this route will also give you 5-lug wheels. Mike B  | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Parts for your truck are readily available. Local Napa as suggested is a good place to start. Also LMC and some others that specialize in parts for these old trucks can help.
Stock brakes maintained properly work quite well for a stock truck. If pulling a load always allow more stopping time regardless of what braking system you have.
Or you can put disc up front, drum on back, or disc all the way around.
My 58 has stock braking system on it and stops the truck as well as my VW with disc brakes. The big disadvantage is if you break a hose or line and lose your fluid you have no brakes. Also the disc brakes cool quicker and aren't quite as prone to brake fade from heat.
But I can lock the wheels on my truck as well as I can a car with disc brakes. Just allow a little more stopping time for the sake of it. Once you're used to how they work, you'll be fine. | | | | | Joined: Feb 2012 Posts: 27 New Guy | | New Guy Joined: Feb 2012 Posts: 27 | Im planning on keeping the brake system original with 6 lug hubs right now.
So i'm looking into drum brakes front and rear, possibly getting a dual master cylinder.
Does this dual master cylinder seem like a good upgrade and would work with drum brakes? Thanks- http://www.ebay.com/itm/1955-59-Chevy-Truck-Frame-Mount-7-Dual-POWER-BRAKE-Booster-Kit-FOR-SALE-/271175450906?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AChevrolet%7CModel%3ATruck&hash=item3f2351011a&vxp=mtr | | |
