| | | Forums66 Topics128,005 Posts1,055,254 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 8 New Guy | | New Guy Joined: Jan 2013 Posts: 8 | Hey bought what I believe is 1936 Chevy 1 1/2 ton truck no Vin tag only the numbers on the engine block casting is either 836010-10 or 636010-10 and the numbers stamped on the pad froward of the distributor are T5898296. Any help would be greatly appreciated. Thanks!! | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Try this for starters. It's from 1937 but maybe the same or similar? 1937 manualTj
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2013 Posts: 8 New Guy | | New Guy Joined: Jan 2013 Posts: 8 | Thanks for the help. Trying to get title lind up from DMV. If I can figure out how to post a pic of it I will. Tim | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Tim and All, There is a mistake on that page, ALL Chevrolet's in 1935 and 36 used the same 207 ci engine (there were no 181 or 194 engines installed in 35/36). The only difference between car and truck were the bolt on items which accounted for the HP differences. Mike B
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Hey bought what I believe is 1936 Chevy 1 1/2 ton truck no Vin tag only the numbers on the engine block casting is either 836010-10 or 636010-10 and the numbers stamped on the pad froward of the distributor are T5898296. Any help would be greatly appreciated. Thanks!! 836010 is a good number for 1936. The 10 after the casting part number is the casting mold number. The engine sreial number is also good. The "T" indicates Truck. Serial number 5898296 was built in January 1936. The 1936 numbers started with 5500179 and ended with 6784512. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the correction, Mike.
I'll look for other sources and correct the information for those years. Most of the on-line sources I got the information from (10+ years ago) are no longer on-line.
