Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (46 Texaco, FAST55, Pete O), 137 guests, and 4 robots.
Topics128,283
Posts1,058,519
Members48,490
Hi.....I understand that a lean condition will cause pops on a downhill on compression. So I turned the screw at the base of my Rodchester B out about 1/2 turn from where it was set and it helped...but.....how much is enough. I'm afraid of losing the spring and needle. I have the engine tuned by the vacuum method and the needle is steady at 19 at 2800 foot elevation and about 650 rpm idle. She runs a treat but when on compression down a hill I get those small rumble farts which my wife hates. Thanks in advance for your help to us.
Steve
Riding in the Passing Lane
Its true, richening the mixture will solve or help it. If you want to tighten the spring on the needle valve you can add a flat washer or 2 behind it but if you only have 1-2 threads left you will need to turn it in a little. A different muffler might help.
1972 Chevy c10 Cheyenne Super
ODSS Lawman
ODSS Lawman
Simple.
Press clutch in on downhill (if the grade isn't too long) and pops go away.
Or do what I do and when it pops, tell her its the Jake brake!!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
It sounds like you are getting air into the exhaust system, But first make sure it has a full tune up. To check for exhaust leaks with the engine idling start at the head to exhaust manifold joint look and listen for leaks and work your way back to the end of exhaust pipe. Pay close attention to the connections before and after the muffler, Make sure that you have a tail pipe to the rear bumper or tailgate, if nothing else it moves the pops and farts to the back of the truck.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
What kind of exhaust system are you running?
Check the timing, and look for an exhaust leak, like others have said.Doesn't take much of a leak to do what you describe.
Tommy
59 apache 1/2t
261 short stepside
Thanks all for your ideas. I will check out all the items that were suggested and report back. The exhausted a split manifold was done by the PO the weld is tight and there are no holes in the system. I think I will re-time the engine to the BB and see what gives. Timing to the BB may produce knock so maybe a few degrees before the BB??..We have an adjustable timing light. Mr. Langdon suggest 10 BTDC but our 235 is not happy with that set-up.
Thanks, Steve
