| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92944 09/17/2005 2:38 PM | Joined: Jul 2005 Posts: 27 Junior Member | | Junior Member Joined: Jul 2005 Posts: 27 | I hope some can help here. My temp and fuel gauge peg out when I turn lights on, it's like abad ground but they work fine until I hit the lights. 66 gmc rewired with painless wiring, all is good but the light and gauge thing. Jeffrey.
I'm older than my truck but it's smarter than me! 66 GMC 3/4 ton fleetside 283, turbo 400.
#92945 09/17/2005 7:36 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | A couple of possibilities come to mind.
The wires from the light switch could be going to the gauges rather than to the lights for the gauges.
The gauges are low current devices and have a good enough ground when the lights are off, but not good enough for the added current of the lights. The gauges could be grounded through the light filaments, which would dissappear when the light were on. | | |
#92946 09/17/2005 7:40 PM | Joined: Jul 2005 Posts: 27 Junior Member | | Junior Member Joined: Jul 2005 Posts: 27 | I just figured it out. T he ground wire for gauges came loose, Thanks for advice anyway.
#92947 09/18/2005 10:34 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That would be because of the last scenario Baldy posed. The gauges could be grounded through the light filaments, which would dissappear when the light were on. The guages were finding a ground the only place they could. | | |
