0 members (), 74 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#92933 09/13/2005 2:35 PM
Apprentice
Apprentice
I have a 1961 Chevy SWB, previous owner dropped a SB 350 under the hood. The problem is I am not getting any reading from my gas tank to show me how much fuel I have in the tank. Anyone have a quick check that I can do to find out the problem?
I am also having trouble with the light on the dash, speedometer and temperature reading.
Please contact me at [email protected] or leave a reply here.
John jsrcts@aol.com
ps: I also want to change out my ignition switch, it currently does not require a key and would like to change that quick. Any recommendations on which one to use?
#92934 09/13/2005 3:10 PM
i would assume bad wiring or a blown fuse or two in the instrument cluster. try taking a test light to check the power at the guages, if no power trace back till you find the problem. as far as the gas gauge its either the gauge or the sending unit. you may have a mismatch if the previous owner changed the sending unit or the gauge. thats what i'm dealing with. incorrect gauge purchased by my PO and my gauge reads full all the time. good luck
#92935 09/13/2005 7:43 PM
Apprentice
Apprentice
Thanks Troy, I will try that.
#92936 09/13/2005 10:19 PM
Riding in the Passing Lane
Disconnect the wire at the tank unit. Turn on the switch & the gauge should go way over on full. Ground the wire & the gauge should go to empty. If that works the problem is the sending unit in the tank. Be shure there is a ground wire from the tank to the body. smile
1972 Chevy c10 Cheyenne Super
#92937 09/14/2005 12:06 AM
Not to steal from oil, but i also have a sensor prob. My gas guage says its half full when its empty,whats the prob.?
#92938 09/14/2005 10:43 PM
Always double check your ground wire and make sure you have a good ground @ the tank itself.
Jim & Caroline
#92939 09/15/2005 10:36 PM
Hey SC your float might be hanging up. If your tank is behind the seat it,s real easy to pull the sender out & hook up the wires & move it through it,s travel & watch the gauge.
