1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
#929063 03/20/2013 4:34 PM
have a 48 gmc 1/2ton, install dual bowl master cylinder, my brake pedal doesn't seem to come up all the way, I can tell cause I put in a new brake switch and it just touches the lever, the only way it will come up all the way is if I pull up on it, unless I put something to take up the space...
696969 #929095 03/20/2013 5:55 PM
3B Offline
Hy 696969, have you got a return spring on your brake pedal linkage?
696969 #929115 03/20/2013 6:42 PM
i will have to check, let you know tomorrow...
696969 #929416 03/21/2013 5:33 PM
I don't see a returned spring, where does it attach to...
696969 #929418 03/21/2013 5:40 PM
considering you have modified your system, that's up to you to decide, a return spring would be attached where ever appropriate wink usually so that it pulls the pedal arm the opposite direction from it's push on the MC activating rod - enough to return the pedal fully
696969 #929422 03/21/2013 5:50 PM
thanks for info guys...
