2 members (ShopRag, DaveV), 97 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#928513 03/18/2013 4:39 PM
Torque tube 1/2 ton.What is the best way to get enough clearance betwean trans and tourque tube.To remove the Ball coller ,whith out removing trans or crossover ,is there a way.Thanks
What year truck?
on my 50 I had to remove the crossmember
...pic...
...pic...
Then lower the tube, support it with a floor jack
47-53?
You should be able to push the u-joint rear yoke back far enough to allow the torque-tube to be pushed upwards. Then you would be able to remove the u-joint, ball/bell-cover/housing, collar, and rear yoke. I hold the torque-tube up with a 2x4 that sits cross-wise in the frame side rails under the torque-tube.
Do you go through the transmission inspection cover for that to work?
I do not think so - maybe I am misunderstanding the first post.
What transmission inspection cover are you referring to?
The one in the cab floor
...pic...
Yes, I would consider removing the transmission floor cover to do that work more easily than from below (but, I have done it from below without removing the floor cover).
4-speed floor cover
3-speed floor cover
I could not get the ball collar off from the top, maybe that's 4 speed only
...pic...
I tried
Yes, it does look impossible with the 4-speed. Thank you for correcting this - my recollection is most likely for a 3-speed (but, now I am even doubting that).
