| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | Torque tube 1/2 ton.What is the best way to get enough clearance betwean trans and tourque tube.To remove the Ball coller ,whith out removing trans or crossover ,is there a way.Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What year truck? on my 50 I had to remove the crossmember ...pic... ...pic... Then lower the tube, support it with a floor jack | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Torque tube 1/2 ton.What is the best way to get enough clearance betwean trans and tourque tube.To remove the Ball coller ,whith out removing trans or crossover ,is there a way.Thanks 47-53? You should be able to push the u-joint rear yoke back far enough to allow the torque-tube to be pushed upwards. Then you would be able to remove the u-joint, ball/bell-cover/housing, collar, and rear yoke. I hold the torque-tube up with a 2x4 that sits cross-wise in the frame side rails under the torque-tube. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You should be able to push the u-joint rear yoke back far enough to allow the torque-tube to be pushed upwards. Then you would be able to remove the u-joint, ball/bell-cover/housing, collar, and rear yoke. Do you go through the transmission inspection cover for that to work? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not think so - maybe I am misunderstanding the first post.
What transmission inspection cover are you referring to?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The one in the cab floor ...pic... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, I would consider removing the transmission floor cover to do that work more easily than from below (but, I have done it from below without removing the floor cover). 4-speed floor cover 3-speed floor cover | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I could not get the ball collar off from the top, maybe that's 4 speed only ...pic... I tried | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, it does look impossible with the 4-speed. Thank you for correcting this - my recollection is most likely for a 3-speed (but, now I am even doubting that).
