7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Anyone looking for a 235? There was one at KMS in Coquitlam. Must be from a big bolt, since it had a drive shaft parking brake. The guy I talked to knew nothing about it. It has a 4 speed with it, also the external oil filter. I wasn't on the ball, didn't get the serial number off of it, so I don't know the year. Had a 12 volt generator on it. Had a $400 price tag. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2006 Posts: 139 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 139 | i have a 1955 235 that was rebuilt along with 3 spd trans which came out of a 1955 Bel air that is complete right down to the oil bath air cleaner and 12 v generator. not sure if the car trans will work in a truck or not. $350 for the works! I paid more than that for it. I am in the middle of installing a sml blk v8 into my 53 p/u that I had intended to put this engine into.
1947 Studebaker M15 on 76 GMC one ton dually chassis with 454 4 spd 1953 Chevrolet 1/2 ton p/u 1957 Oldsmobile 88 2dr hardtop 1959 B130 International one ton dually | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy burgundybolt, you can consider that engine sold, could you bring it with you when you come out to the picnic this year? That is if the monsoons don't start up again! | | |
