5 members (Denny Graham, Steelonsteel, 66flea, treegrower, Otto Skorzeny), 52 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#928579 03/18/2013 9:02 PM
Hello,
I'm replacing the timing cover on my 235, I accidently drilled a hole through the cover (newbie). I noticed the felpro timing gasket set comes with the water pump gasket and the front plate gasket. Do you need to install the front plate gasket to prevent any front motor oil leaks?
1946 Chevy Truck Export Blue with Black Trim
It would require removing the cam to pull the timing plate.
I would not bother.
My Blog
yup
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
