0 members (),
100
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92843 09/02/2005 4:51 AM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | Just wanted to get some thoughts on whether its cheaper in the long run to buy an aftermarket wire harness for my 65 or if I can do it myself for a reasonable price... I do have complete and detailed wiring diagram for my truck... anyone have any ideas?
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
#92844 09/02/2005 7:01 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | My answer was already given in the General discussion section. Cecil......... | | |
#92845 09/03/2005 12:46 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Considering the dangers and problems involved with old wires ... and with countless splices and "quick fixes" made by PO's ... my vote goes to a rewire job. The EZ-Wire kit is only $160 and isn't brain surgery or rocket science. Check out my many notes Here And if you want to go further, read this ... as well as the links at the bottom of the page.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#92846 09/10/2005 4:14 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I bought a painless system for my 59 and it worked very well. I recommend it. On my 47 jeep, I did it myself, and other than one boo boo, I actually improved the system with a new fuse box I bought for cheap.
The wiring harness you buy has all the wires labled and near the right right length. When you do it yourself, you have to decide on wire colors and make a lot of notes. Now for the jeep, there is no heat, no radio, no turn signals, and very little else. So myself was cheaper and worth it. On my truck with all the other junque, I think the wiring harness is a better answer. Especially if you look to add stuff down the road. It is a neater install too. | | |
#92847 09/11/2005 5:41 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Do you have experience wiring vehicles? If you've not done it a few times before I would suggest buying a kit.
Its hard to buy the parts at the price of the cheaper kits. So unless you have some real good reason for creating your own wiring harness, I think the smart move is to buy one.
That said I've wired several from scratch. I might do it again, but only if I'm convinced I need something a kit won't support. Right now I've no idea what that might be.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92848 09/20/2005 6:22 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Often times Steve (oldsub) you can buy the kit and add to it the circuits you need. It's smart to buy a fuse panel larger than you think you need and /or relays to add to the system.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#92849 09/20/2005 8:37 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Ditto what everyone else says... do yourself a favor and buy the harness.. Even if you have the wire and experience it's the most logical way to go... everything's wrapped, plugs are attached and numbered, etc. it's all "wire-by-number". | | |
