| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | First time on Stovebolt. I'm doing a frame off resto on my 61 Apache and can't find the tar paper like material used to insulate the cab between the gas tank and the rear of the cab. I've searched all the sources on line and do not like the offerings. I'm trying to keep the truck as original as possible. Any suggestions?? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | We use two layers of Fatmat, Hushmat or Peel-N-Seal, stuck to each other for the correct thickness, for the saddle cushions on the bottom of the fuel tank and under the tank straps. | | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | Thanks. The piece I'm refering to is one whole sheet glued to the inside of the back of the cap under the rear window. Looks like thick tar paper with a diamond pattern pressed into it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... Looks like thick tar paper with a diamond pattern pressed into it. that's just what it was, if you're trying to copy the factory, the closest thing you'll find is the heavy "50#" roofing paper Bill | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I have never seen a whole sheet behind the tank, below the window. Learn something new everyday. Thanks for the nugget.
| | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | Bill,
Many Thanks!!!
The 50# roofing paper was my choice if I could not find a reproduction piece.
That insulation was part of the "Custom Comfort Option" from the factory. Boy have things come a long way from a piece of tar paper being an extra option.
Custom Comfort Option - left arm rest...right-hand sunshade...chrome cigar lighter...full six inch foam rubber seat cushion with special trim...special cab insulation...left-hand door outside key lock.
Any body know what that option cost in 1961???
Steve | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The place were you pulled that information, will tell you what this R.P.O. costs.
The extra insulation can also be found, in the form of jute insulation, adhered to the underside of the dash, from the cardboard cover, to the intersection with the dash shell.
| | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | Tony,
I found that description of the "Custom Comfort Option" in a sales handout... No prices are listed. I don't know were the R.P.O. prices are listed.
Thanks for the tip on the dash insulation...
Steve | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Per the Truck Sales Data Book:
Cab, Custom (extra foam seat & left door lock) Except Fleetside Pickups - MSRP - $96.85 Fleetside Pickups Only - MSRP - $107.60
Lock: Left Door - MSRP - $1.65
Seat, Custom (De Luxe Cab Only) - MSRP - $17.25
Here are a few more, of interest:
Window, Full View Rear - MSRP - $43.05
Engine, Trademaster V8 (160-hp) Includes 11" clutch & oil filter - MSRP - $118.40
Paint, Exterior: 2-Tone (Cabs, except fleetsides) - MSRP - $16.15 2-Tone (Fleetside) - MSRP - $32.30 2-Tone (Panel or Carryall) - MSRP - $26.90
Heater & Defroster: De Luxe; outside air - MSRP - $68.35 Recirculating; inside air - MSRP - $47.90
