1 members (Bill Hanlon), 138 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#92811 08/28/2005 11:16 PM
I
I Offline
Here is the new wiring diagram I made up for my '48.
48 wiring
I am running a one wire alternator and HEI setup so there is no regulator or coil shown.
Just thought I'd share it with the rest of you.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#92812 08/28/2005 11:35 PM
Nice work Inky. What did you use to create the diagram?
#92813 08/28/2005 11:43 PM
I
I Offline
I drew it in AutoCad and converted it to both JPG and PNG formats so I could post it. I posted the PNG because it is a little better quality.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#92814 11/10/2005 8:51 PM
Junior Member
Junior Member
Thanks for the diagram!
Where did you get the HEI distributer? Did that help the truck run over 45mph
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
#92815 11/10/2005 10:23 PM
I
I Offline
HEI from 82 chevy 250. Not for increase in speed... just reliability.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#92816 11/17/2005 12:29 AM
Excuse my ignorance. What is an HEI.
I just bought a 1953 Chevy 3100 with a 235 inline that came out of a 1958. I'm just curious though there is soooo much I need to do before I even get to the wiring.
#92817 11/17/2005 1:13 AM
Mario23,
HEI is an acronym for High Energy Ignition. It is a solid state, or breakerless distributor.
Stuart
#92818 11/17/2005 2:15 AM
Ok thanks. So what I have to figure out is if I already have this thing already under my hood being that its a 58 235 engine...
I'm learning. Believe me, I've learned alot in the past few days with much more to go...
#92819 11/18/2005 10:11 PM
Junior Member
Junior Member
OK Ink05, I ran wires from the two tail lights up to the cab. One side went to the Brake sw and the other went to the fuze box to the tail light fuze. When I bulled the lights on the running lights worked, but I could not get the brake lights to work. I had power up to the NEW BRAKE switch but when I had the pedel pushed down the switch would not make the connection to the other wire. I purchased a New brake sw to avoid this problem:( I did use the old connector to attach the new wire to the sw.
I am using a light prob to check for power.
What Now???
I do have power to one side of the Brake sw but I am not having any luck wiht the brake sw. Oh ya, Now my dam truck wont start. I put the battery charger on it for a few days to make sure I have a good charge.
#92820 11/19/2005 12:19 AM
Mario23,
A GM HEI cap is just a little smaller than the Hindenburg...easy to identify.
N D Loadmaster,
Use your probe and work backwards from the SUPPLY side of the brake switch, you said you know you have power there, check it again. Then probe the other side of the switch..manipulate the switch until you get power there. Go to the back of the truck and poke the wire with the probe..it should be hot. You should be able to get to the tail light and still have power.
If you have power all the way to the socket, and still no brake light...check, replace or wiggle the bulb. That lamp is the stop/tail combo so it goes in only one way. If this is all perfect, and still no light, you need to investigate the ground. Nothing works without a ground.
Using the probe, start at the known source of power and work toward the problem. You will come to a point in system where power is no longer present....you found the problem! Have your wife, girlfriend, neighbor or child help you. They can push a brake pedal or watch a light.
Don't think because the brake switch is NEW that it works...PROVE it works with a meter or your probe. Your brake arm must go down far enough to make the brake switch close.
Stuart
