3 members (Otto Skorzeny, MNSmith, Gray_Ghost), 63 guests, and 1 robot.
Topics128,057
Posts1,055,812
#926703 03/11/2013 8:36 PM
I need some pictures and info on how the clutch linkage is set up on my 56 3100. I have installed a 250 with a 435.Thanks........
FREE1956 #926716 03/11/2013 8:58 PM
doesn't sound like anything you'll find pictures of, a 56 Chevy didn't come with a 250, and what's a '435'?
FREE1956 #926773 03/12/2013 4:59 AM
Its a new process 435 4 speed from a 72 chevy..
FREE1956 #926778 03/12/2013 5:46 AM
Bill,
I think he means SM 465 4 speed,which replaced the SM 420 in 1968/69.
never heard of a sm435
steve sr.
FREE1956 #926795 03/12/2013 7:02 AM
huh, Ford transmission who'da thunk .... look at picture upper left here - #8 & 9 are the pieces in the correct relation for the 55-59 clutch linkage, left end of 9 hooks in the pedal eye, return spring goes from where 8/9 join to an oil pan bolt .... don't know if that'll work with what ever bell house you have
FREE1956 #926945 03/12/2013 5:40 PM
It's a 435. I tracked down some parts and got it back in shape..I traded for the motor and transmission.. It runs great..
FREE1956 #927011 03/12/2013 9:44 PM
Are you talking about the bellcrank that goes between the block and frame on the the 250? If so, ignore it and use the '56 linkage bill suggests.
Les
FREE1956 #927281 03/13/2013 7:27 PM
The fork is a bit different but I think it will work. Ordered the 56 stuff today.... Thanks for the help.....
FREE1956 #928084 03/17/2013 12:09 AM
red58
Bill,
New one on me.
Never dealt with a fj,kd thats why I would have never Known about that gear box!
Never saw it in a G.M. truck all these yrs.
Just assumed we were dealing with Normal G.M. Products.
steve sr.
FREE1956 #928805 03/19/2013 7:48 PM
New process made transfer case's for GM for years..I had to enlarge the clutch fork hole but other than that it all worked great.. Not sure where to hook the spring though??? Thanks for the info......
FREE1956 #928825 03/19/2013 9:00 PM
435 was used by Ford and Dodge but did make some for Chevy in '72 time frame. They can be detected by an aluminum top cover.
I've never seen a Chevy version myself but it should bolt to the 56 bell and use the standard fork...
FREE1956 #928858 03/20/2013 12:03 AM
Back when I worked for a construction company there was one in one of there 1972 Chev 1 tons.
My Blog
