0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#92798 08/28/2005 10:28 PM
I'm tired of maintaining six volt batteries to run a truck I only start once or twice a year. So I decided to convert my '52 6400 to 12 volts.
I bought a 12-volt coil and an ignition resistor and started wiring. Suddenly I realized that with a foot starter there is no readily available electrical connection that bypasses the ignition resistor when you press the foot start.
Anyone found a slick solution for this problem? What have others done?
The cleanest solution that has come to my mind so far is converting to an HEI, but that defeats the less trouble purpose I started with....
#92799 08/29/2005 12:12 AM
A foot start mechanism from a second series up should have the coil terminal.
Insomniac
Insomniac
How about a monentary contact push button under the dash you can press and hold while starting?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Quote
I didn't know those existed. Thanks for the tip, I'll look for one of those!
Quote
That would work but its the kind of solution I want to avoid...
I'd almost rather use some kind of current surge measurement to trigger a relay than push another button. Maybe I should give up and put a selenoid starter in instead.
I have what baldy described. Works great. It's the contact that bolts to the starter. It has an extra terminal on it just for this. Check out Chevy Duty Part # 53-712
Switch pic
If you use the stock 2/0 6V battery cables on your 12v conversion you don't need that bypass contact. My truck cranks and starts just fine in 10 degree weather without it.
Paint & Body Shop moderator
#92805 08/29/2005 11:00 PM
Quote
Hadn't thought of that... But the fact that those cables are already long gone is one of the reasons I was tired of fighting the six-volt battle.
I bet it works just fine.
#92806 08/30/2005 12:12 AM
I just used the 6 volt coil with the resistor feeding the coil...????? 6v to the coil all the time...??? why not do that..???
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#92807 08/30/2005 12:48 AM
Using the six volt coil is not longer an option because one of the posts broke off when I tried to remove the wire.
It was actually that event, which occured while I was troubleshooting, the moved this conversion from a thought to a sure thing.
You will not need the by-pass if you use the fat battery cables as described above. Also to simplify things a lot go to NAPA and get an IC64 Ignition coil with the built-in resistor. A lot less headaches and a lot more reliblity.....Randy
get cables for a tractor there heavy and cheape i just got a 12 voit coil and a resister mine starts fine
#92810 09/13/2005 10:56 PM
Buy a switch similar to your brake light switch, mount it in such a way that your foot start mechanism operates it, and use it to short out the resistor.
Johannes
Simplicity leads to reliability.
