| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 21 New Guy | | New Guy Joined: Mar 2013 Posts: 21 | my truck is a 1.5 ton I believe it is a 1941 or close to it, the engine number now is BDR 15592, I'm not 100% sure if the motor has ever been changed but I see on the original ownership papers that came with the truck it has another number BFR 246846, this number has been crossed out, not sure if this was a mistake originally or if this may have been the original motor? | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | As long as she's single. :>)
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only codes I can find that are close are for 1942. BD comes up as a Flint produced 216 for a 1/2 ton pickup, BF is also a Flint produced 216, but for a 1.5 ton Conventional cab truck. I couldn't find any codes with an "R" as part of the code, perhaps it might have to do with the truck being an Export model?
Bill Burmeister | | | | | Joined: Mar 2013 Posts: 21 New Guy | | New Guy Joined: Mar 2013 Posts: 21 | Thanks, I've been out & checked the number on the engine it definately has th R on the block, it is a 216, its not a pickup so there may be the chance that the engine was changed at some stage from the original BFR to the BDR code | | | | | Joined: Mar 2013 Posts: 21 New Guy | | New Guy Joined: Mar 2013 Posts: 21 | Are the specs different between the BF & BR engines? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Are your numbers machine or hand stamped? The "R" could be "replacement"... Mike B  | | | | | Joined: Mar 2013 Posts: 21 New Guy | | New Guy Joined: Mar 2013 Posts: 21 | machine stamped, all the same size, spacing & style | | | | | Joined: Mar 2013 Posts: 21 New Guy | | New Guy Joined: Mar 2013 Posts: 21 | it sounds as if the BD & BF are Flint produced 216 and the R is for RHD | | |
