2 members (RLB, Guitplayer), 139 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#927998 03/16/2013 5:30 PM
my truck is a 1.5 ton I believe it is a 1941 or close to it, the engine number now is BDR 15592, I'm not 100% sure if the motor has ever been changed but I see on the original ownership papers that came with the truck it has another number BFR 246846, this number has been crossed out, not sure if this was a mistake originally or if this may have been the original motor?
As long as she's single. :>)
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
The only codes I can find that are close are for 1942. BD comes up as a Flint produced 216 for a 1/2 ton pickup, BF is also a Flint produced 216, but for a 1.5 ton Conventional cab truck. I couldn't find any codes with an "R" as part of the code, perhaps it might have to do with the truck being an Export model?
Bill Burmeister
Thanks, I've been out & checked the number on the engine it definately has th R on the block, it is a 216, its not a pickup so there may be the chance that the engine was changed at some stage from the original BFR to the BDR code
Are the specs different between the BF & BR engines?
Are your numbers machine or hand stamped? The "R" could be "replacement"...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
machine stamped, all the same size, spacing & style
it sounds as if the BD & BF are Flint produced 216 and the R is for RHD
