7 members (D B Cooper, 55shaker, GMCJammer51, MickeyP, ndkid275, Phak1, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | I'm new to this forum and am asking for some informed opinions and advice. I have a 53 GMC 1/2 ton 228 with hydramatic. The engine needs rebuilt. I would like to replace it with a 302. I really want to keep a six cyl and hydro. Questions: Will a 302 fit the mounts and hydro? Are 302s readily available? | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | 270s and 302 can be found but they are harder to come by then 235s or 216s. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 302 will bolt right in. If it has side mounts you will need to replace the mount plate on front to use your mounts.
Also, the 228 most likely has a 4 bolt crank and the 302 a 6 bolt. You'll need to find a 6 bolt torus cover for the Hydra-Matic.
Both these problems are easily overcome and well worth the effort. | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | I'm getting convinced to go with a 302 if I can find one. My 228 has the front center pad so mounting the 302 shouldn't be too messy. I hope. What is this torus cover you mentioned? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Instead of a torque converter the Hydra-Matic uses a torus. You'll have to get the Hydra-Matic experts to tell you how it works. Anyway, the cover to it mates to the crankshaft. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | are you staying six volt or converting it to 12? | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | I would like to stay with 6 volt. The truck is totally complete with only the radio missing. The 228 is frozen and if it is not rebuildable I thought of going to a 302 for the power advantages yet maintain the same appearance to a non purist. | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | By easy to solve do you mean that a 6 bolt torus can be found for a reasonable price? This is my first old truck rebuild and I have soooo much to learn. Will my newly rebuilt 228 starter fit the 302 bell housing and flywheel? Just a bunch of stuff like that. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm getting convinced to go with a 302 if I can find one. Is your truck titled using the engine number? Many, if not most, pre '56 vehicles were. If so you'll need to re-title your truck following the swap. We got LOTS of questions about titling problems for that very reason (engine swaps without retitling). People buy a truck and can't find the "VIN" that's on the title anywhere on it.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A torus cover from a '54-55.1 248 will be 6 bolt and will mesh with a 6V starter. If you get a later cover you will need a 12V starter. | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | That's a good point about the title. I am in the middle of the title process now wherein a police officer has to verify the engine number. I will probably keep the old 228 around for the inspection process to validate the old title then use the new engine number on the new title. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If it were me, I'd see if you can get the Chassis Serial Number put on the title to end the problem with swapping motors and not having the title match. Mike B  | | |
