1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 19 New Guy | | New Guy Joined: Mar 2013 Posts: 19 | I need a little help here. I can't figure out for the life of me where the E-brake return spring hooks into, both ends. ??? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What year and make is your truck? | | | | | Joined: Mar 2013 Posts: 19 New Guy | | New Guy Joined: Mar 2013 Posts: 19 | Opps sorry, forgot that part. '51, 1/2 ton. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It has a washer on the floor side the same diameter as the spring it basically floats on the shaft. You push the pedal in and it compresses, then when you release it pushes back out. It really does not hook to anything. Sometimes depending on the hole in the floor panel they will kind of twist in there and stick but they don't attach. | | | | | Joined: Mar 2013 Posts: 19 New Guy | | New Guy Joined: Mar 2013 Posts: 19 | I have the spring your referring too. Then the light came on, http://www.oldchevytrucks.com/cart/product.asp?prodid=ME156&i=9879||||| It's the brake cable with the spring inside the drum that pulls the lever, that turns the shaft, that pulls the 40 some inch rod, that pulls the E-brake peddle to vertical or some part there of. From time to time I can't find the light switch.
Thanks for your help. | | |
