9 members (Peggy M, Otto Skorzeny, tclederman, Shade Baby, DadsFirstPickup, FAST55, Bucker, wilbur53, 1 invisible),
78
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | For a 216 engine, have been through two cylinder heads already. Both were found to be cracked by engine shop. When I talk to salvage yards they don't really check them ahead of time and the shipping is expensive. Any advice on finding a non-cracked cylinder head? Is it the freezing and thawing that cracks them? Should I be looking in Arizona? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Freezing and thawing will do it. Overheating will do it.
I remember friends in the 70s saying "good luck finding a 216/235/261 head, they are all cracked"
They are not all cracked. But, I bet the ones in a dismantling yards have good reason to be suspect for cracks.
If I was buying a head, I'd pay to have it magnafluxed and certified to be uncracked, then I'd know I was paying for shipping a good head. I'd try to negotiate on the cost of head, due to need to magnaflux it.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I can't believe that you don't have some junk yards around you that you can't look thru.I just got two heads and a 58 235 out of one that was an hours drive from the house.Total cost 150.00 plus got rebuildable fuel pumps,carbs,distributors and a ton of spare parts.I also found a spare zenith that was on a GMC pickup and a carter 2100s that was on a Chevy pickup from two trucks at 15.00 each.
I'll bet that if you put an ad in Parts Wanted you'd find someone with a 216 in you're area,I got a 216 head that I ran on my 52 but the shipping would be expensive.
Pete | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 |
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Appreciate the feedback. Truck is 1950 but the engine i.d. numbers are consistent with 1948. I search salvage yards through car-parts.com but they are all out west. | | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | I can't believe that you don't have some junk yards around you that you can't look thru.I just got two heads and a 58 235 out of one that was an hours drive from the house.Total cost 150.00 plus got rebuildable fuel pumps,carbs,distributors and a ton of spare parts.I also found a spare zenith that was on a GMC pickup and a carter 2100s that was on a Chevy pickup from two trucks at 15.00 each.
Pete Has it been magnafluxed?! If it has no cracks i'll come buy it! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It was not magnafluxed but it ran good before the rebuild and when I had it in my truck,for a year.
Pete | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Did u find a 216 head? I've got a good one I'll give U !!!! My 52 that is for sale and I will be at the Carlisle, Pa. auction on April 25th. If u haven't found one and want this one, I will bring it to Carlisle. I've got the head bolts, push rods, valve cover. Head was just on a running 216 that the cops crushed the block because of an altered number.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Did you search through Craig's List for the Ohio and Kentucky areas? http://www.Craigslist.org | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My original 216 head has stress cracks in all cylinders. The cracks are not through to the water jacket and shouldn't cause problems. The machine shop used some type of liquid crack filler just for grins. Not sure exactly what was used, but what the heck. | | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | I found one (from this Forum - thank you!) that was already magnafluxed with no cracks and she's at the engine shop as we speak. Chassis came back from paint yesterday and looks so beautiful I sat in the garage and stared at it. | | |
