4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#92761 08/26/2005 4:37 AM
' Offline
Can any one tell me if my '46 GMC 2 1/2 ton maple leaf is a positive or negative ground? And any ideas where I can get plug wires?
well, GMC's generally were positive ground back then, but no tellin about Maple Leafs - I think actually they were "heavy" Chevy's, in which case they'd be neg ground
for plug wires, any auto parts store should be able to come close enuff - any early GM I6 wires will work - what engine's in it? been changed or original?
the Reynolds Alberta Museum in Wetaskiwin may have some info, if yer not tooo far from there
Just check which terminal of the battery is attached to the frame (If the negative is attached to the frame it is negatively grounded).
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
' Offline
thanks guys I'm about 30minutes away from Reynold's Museum, and the truck had no battery when I aquired this Gem. Thanks again..Scott
Look for a polarity designation on the coil. The side that attaches to the distributor will be the same as your ground.
' Offline
Great you guys have been a great deal of help.
Thanks again..Scott
