4 members (Hotrod Lincoln, BC59, 2 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | PUT 5gallons of gas in tank- float is not sinking has no holes in it.Took both wires off tank sending unit and gas gauge goes to full all the time when key is turned on and back to E on shut off.I am going to put new wires from the sending unit back to the ign and charging gauge maybe that will help? It looks like all factory ORG wires no chop up under dash. All electric gauges have power and dash has light. DID look for wires touching frame-nothing found.any other tips will be helpful.THANKS | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Make sure the sending unit is grounded (run a wire from an attachment screw to a good ground).
