1 members (WICruiser),
164
0
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | if memory serves me right, the wire to the gas guage is hot in, ground to the tank, right? have the resistor to lower the 12 volts to 6, but have decided not to attempt to blow up the truck.........just yet.
also, does the charge meter need to be converted to 12 volts as well? i figure it does, but just asking.
trying to do away with aftermarket guages and use what is there, b ut all disconnected and ran to aftermarket guages. thanks! | | | | | Joined: Aug 2012 Posts: 10 New Guy | | New Guy Joined: Aug 2012 Posts: 10 | Hi there!
I have done a few 12v conversions and this is what i learned: wire between tank sending unit only sends ohm resistance, the "feed" wire to the gas gauge needs to be dropped to 6v (use a ceramic inline ballast resistor or an electronical Circuit type 7806) The electonic part is a bit hard to install (soldering required) but will provide 6v dead on, which will lead to a more accurate reading)
The charge meter does not care for 6 or 12v just wire it in on your 12v Circuit. (carefull though, if i recall correctly the charge meter originally provides current for gas gauge, instrument cluster bulbs etc) | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | no factory wiring left. just a rats nest of hillbilly rigging for me to deal with. have a resistor that more or less bolts in line, so i figure i'll run a hot from the box to the resistor, then thru the gage to the sender. still gotta figure out the amp though. thanks for the input. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ammeter doesn't care about volts, just amps .... BATT on the regulator to + on the ammeter, - on the ammeter to the battery terminal on the starter
Bill | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | alternator, later model starter. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | still basically the same, output of alt to BATT post on starter, via the ammeter .... one wire or 3 wire alt might make a difference Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If we are talking about an AD truck, the resistor needs to have a value of 30 ohms. A 2 watt resistor will be plenty large enough. That would not be a ceramic resistor. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This fuel gauge voltage reducer is reasonably priced, is reliable, does not need to be soldered, can only be attached one way to the power-input post on back of the fuel gauge (the input/output sides of the reducer are important). | | |
