| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92748 08/23/2005 6:42 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | Some info says how easy or one wire hookup about wiring an HEI to your truck and little about the related starter. Most times the starter does not enter into the info. The original wiring has a Bypass wire from the plus side of the coil to the starter 'R' post. This way the coil ''only in start mode'' has full 12volt positive at the coil. This standard wiring also has a resistor allowing about 9 += volts to the std. points dist. /coil during operation. When wiring for an HEI a larger size wire 10-14 ga. should be placed to the HEI 'BAT' from the key switch ignition post and remove the resistor wire. I have also found notes on eliminating the 'Bypass' wire from 'R' to coil when installing an HEI. Comments please... Then we can talk about the relay for this circuit. jim
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#92749 08/23/2005 6:52 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The HEI does not NEED 10 gauge wire. In conversations with Tom Langdon, the wire size was increased from a "normal size" due to an occasional miss during emissions testing, not because the ampacity of a 10 gauge wire was needed.
My wife's uncle was an engineer for the Motorola automotive products divsion and was on the team which developed the hei module. He says that it will fire down to ~4V. I have found the output to decrease proportionally with voltage and still be plenty at well below 12V. I have found the average current draw to be ~2 amps at 12V.
Just wire it up to a switched 12V supply.
Jason
#92750 08/29/2005 3:00 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | thanks for the info jason
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#92751 08/30/2005 12:17 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | The HEI always runs on 12v.. ya dont need a resistor anywhere...or worry about the starter... as long as the HEI terminal has 12v regardless of the key in ign or start.... dont wire it from the starter,,wire it from the switch......
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
