1 members (Gone), 180 guests, and 1 robot.
Topics128,183
Posts1,057,263
Members48,467
My 56 3600 has huge gaps between the top of the fender, cowl and hood. P/O has the fender mounted UNDER the inner fender liner. Seems to me that it the fender was over the top of the inner fender Id have more in out adjustment and could lessen the gaps. Which way is correct?
that's right, definitely inner on top of outer .... gap between the fenders and cowl are likely a result of the rear attachment points of the outer fenders and would naturally result in a gap to the hood .... fitting the hood is painful
Thanks again for replying to my posts. It is good to know that I don't have to take the truck too far apart to correct these gaps.
My gap is terrible there too. I was thinking it was a problem with the hood hinges. I'll have to take a second look now to see just what you are talking about...can't understand it w/o looking at it.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
