1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | I just asked about the vent on the differential of my '39 JD. I may be barking up the wrong tree. If oil is migrating from the transmission to the differential via the torque tube, perhaps pressure in the transmission is contributing? Anyone know how the 4 speed transmission is vented? I'm hoping against hope that I can improve the problem without haveing to drop the entire differential/driveline assembly to replace the seal in the torque tube. I'd rather drive it than twist wrenches on it.
