2 members (NJC, baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92636 08/12/2005 10:30 PM | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | I picked up a remote starter (2 alligator clips and wired push button) for 6 and 12 volt use, but I can't get it to crank over the starter. No directions with it, so I hooked up one lead to the positive on the starter and the other to ground - push the button and nothing. What am I missing or mis-connecting? Would make it easire to set points / check engine, etc. BW | | |
#92637 08/12/2005 10:38 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | foot stomp starter? the positive on the starter is before the switch so you have to push the switch to get the juice to the starter - your remote switch is for an key start setup get a honkin big screwdriver [or pry bar] and get it between the switch and the firewall, watch distributer, push down on bar - easy, just make sure it's in neutral! Bill | | |
#92638 08/12/2005 10:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should connect one lead to the small wire on the selenoid marked S.It usually is a purple wire. The other is hooked to the pos. cable or any good hot wire. This is for GM. Other makes are different. You probably have fried that remote starter switch though. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#92639 08/12/2005 11:05 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Wrench - your talking about the key switched starter, I think he's got a foot stomp 51, no solenoid - but yer prolly right about fryin the remote switch!
Bill | | |
